メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Beats Solo Proは、常に動き回っているリスナーに最適です。オンイヤーヘッドホンとしては驚くほど効果的なノイズキャンセリング機能を備えています。Beatsの象徴である低音重視のサウンドシグネチャーは健在ですが、ボーカルの再生を邪魔することはほとんどありません。
Why is my solo pro just blinking white light non stop for hours?
It’s just blinking white light for over 24 hours now and it doesn’t connect or turn off even when I tried all the resetting techniques online it’s pretty much useless and sitting there now
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
4件の回答
最も参考になった回答
Hi
This issue is usualy caused by the logic board or the battery
Here’s what to try!
Try leaving them so that the battery goes flat and then try charging them up
You could also try disconnecting the battery by following this guide(this usually works in most cases)https://m.youtube.com/watch?v=SBeHaqnw45...
If the above doesn’t work I would try replacing the battery which uses the same link above
If all these don’t work please let me know
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I just destroyed my headphones trying to unplug the battery 😭😭 thanks so much apple
さんによる
コメントを追加
Hello. Tried all your steps.
Finally changed the battery. And it start again blinking white do you know what I can do more
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
hey man i was having this issue with my beats for the last 3 months, the battery percentages was extremely low to the point where i would plug the beats in to charge and had the similar symptoms that you've experienced. I saw one person say deplete the battery and try to recharge it. And so i did, i keep the beats open / On and had the loudest sound pay until the beats die. I did that until every time I open the headset, it wouldn't connect to my phone. I knew at this point, it was completely dead. Since last night I had allowed the beats to charge after noticing it had reached 35% with the same charging symptoms. At this point, I am currently using the headphones as normal!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine didn't is not on pairing mode I try to hold it in 5 sec it didn't work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Albert Eintein さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 38
過去 30 日: 116
今までの合計 14,145
