Where is the transmission solenoid located
Where is the transmission solenoid located in my 09 Dodge Journey R/T - V6 - 3.5L?
V6 - 3.5L 3497cc 215ci GAS MFI vin V - 4 valve SOHC
Update (08/22/2022)
Yea ... not on my car
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @tonez12
If it is the 6 speed AT then here's the 62TE transmission service section from the repair manual for your model.
It shows how to ID the transmission so that you can check if it is the correct one.
The solenoid (if it is the correct one) is mentioned on p.212-214
Hopefully a start
このアンサーは役に立ちましたか?
Thanks so much
過去 24時間: 2
過去 7 日: 9
過去 30 日: 80
今までの合計 2,415
2 件のコメント
Hi @tonez12,
Does your model vehicle have the 6 speed auto transmission?
jayeff さんによる
6 speed front wheel drive axle I believe ... I'm learning as I go so please bare with me. My journey is a AWD so I'm not sure if that makes a difference.
Rachael Abeyta さんによる
