メインコンテンツにスキップ
Repair information and support for GE Profile Refrigerators.
122回答 すべてを表示
Refrigerator and freezer both stopped cooling
GE Profile Model PYD22KYNCFS stopped cooling both frig and freezer. I cleaned the condenser fan grille and the fan is running. Both the fan in the frig and in the freezer are running. The compressor was warm but could not really tell if it was running so I changed the starter and capacitor, that was no help .The copper tubing from the compressor is cool but not cold. I think it could be a temperature control problem but I'm do not know how to check that. If that is not the problem what do you think it could be? I was thinking a leak in refrigerant but I see no signs of there being a leak, no oils anywhere I can see. Please help send me in the right direction on this. The frig is 1.5 years old
Thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
選択されたソリューション
Hi @jeffbtlv
Here's the mini manual for the refrigerator.
Try running the diagnostics and check if any error codes are displayed.
Hopefully it is not a sealed system problem.
If it is check the warranty. Usually there is a 5 or 10 year warranty on the sealed system
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Thank you so much! Do I have to run each test individually or does it run them all automatically?
さんによる
@jeffbtlv
Each test has to be run individually by using the up/down buttons to step to the desired test
さんによる
Thank you and have a great day!
さんによる
コメントを追加
回答を追加する
Jeff さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 50
