Digitizer touch glass from series 5 works on SE?
Hello, I have successfully separate the glass from the display I damage the touch in process so I had to take out the touch , the question is the digitiser from Apple Watch Series 5 works on SE?
Hi
Iv had a look at some replacement parts and from what I have seen it should work because most of the parts I looked at were compatible with both the SE and the series5
What I would do to be sure is use a replacement part that says it’s compatible with both just to be certain;-)
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 302
