メインコンテンツにスキップ
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
160回答 すべてを表示
Screen black but we can see the image if using a flash light
I have also a problem with one of my a1407 cinéma display .
Screen seems black but we can see the image if using a flash light . If LCD panel swapped with another one it works ok .
So screen is faulty obviously, but would a LCD controller card replacement do the job or I have to change the whole screen .
Cost wise is obviously not the same
Thanks for any return or ideas
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
s.nectoux since it works with another screen it shows you that the backlight on the display is not working. The backlight is part of the panel so you would have to open the panel to repair this. A new LCD controller card will not resolve this issue
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
s.nectoux さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 25
