メインコンテンツにスキップ
DUALSHOCKシリーズの後継機種である初代Sony PlayStation 5 DualSenseコントローラーの修理ガイド、分解、トラブルシューティング情報。 型番はCFI-ZCT1W、マザーボードの型番はBDM-010です。
L2 Button constant on even if not pushed
Hello,
i changed the two rings around the L3 button which caused stick drift , after getting all stuff together my L2 Button is like always enabled even if im not pushing it at all. How can i fix this ? Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
最も参考になった回答
Try taking the controller apart again and then push the L2 button then release. If that doesn't work ,try replacing the trigger button. Hope this helps!
Diode
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
tested some stuff and the L2 is even activated after i removed the left L1 and L2 unit from motherboard. So its something with the board i assume.
さんによる
@Toni Montana Seems that way. All right. I don't know if I can help you in any other way. Sorry.
さんによる
its a problem with the blue flat cable that connects the unit to the main board… try straightening the metals at the tip… worked for me
さんによる
コメントを追加
Usually it happens when the board is loose. There's one screw that atach the board to the controller shell. Open the controller again and Make sure you've tightened it.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I had the same issue and Younes is correct. The L1/L2/R1/R2 buttons are in same circuit as all the other buttons. Underneath the circuit board is a pad with 16 connections that needs to make contact with circuit board. That pad was out of alignment on my controller and I was having the same issue with the R2 button. Realigning the pad and tightening down the circuit board fixed the issue.
さんによる
コメントを追加
when I had close to the same problem, I had to replace the spring on the side of the trigger. Also, I completely disassembled and clean the adaptive trigger with contact cleaner bw-100, but the spring was my real problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The small white ribbon cable that connects the trigger rumble pack to the board if you look very closely at the blue tab end you'll notice the gold connection lines, these are very thin and can bend easily, get a new ribbon cable or try to straighten it and trial and error it until it works (keep the casing off and try a game like astrobot until it's satisfactory)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Toni Montana さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 81
過去 30 日: 447
今までの合計 19,936
