メインコンテンツにスキップ
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
85回答 すべてを表示
Why is my Ti84 plus ce not turning on?
Hi I have a TI84 Plus CE-T that Is not powering on. I have been able to power it on once or twice but it froze and when I pressed the reset button it immediately shut off and did not turn on again even when put to charge. Sometimes though when I put it to charge the back-light turns on but the screen just stays black and when you try to reset the calculator it immediately turns of. Once when I put it to charge the screen turned on with a white blank screen but just shut off a few minutes later. When I did turn it on I downloaded some application using ti connect and everything worked perfectly fine but it shut off when I pressed the reset button and did not turn on.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Try following the recovery guide starting with step 4, an OS reinstall: TI-84 Plus CE Recovery Techniques.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi
I have tried everything in the video that you have suggested above but have had no luck at all. When I try holding 2nd, del and the reset button nothing happens no matter how much I try I have had no luck. I have tried almost every troubleshooting method I could find both online and on the TI website and nothing has worked and this point I am loosing hope in this calculator.
さんによる
コメントを追加
回答を追加する
Brayan Gijo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 97
