メインコンテンツにスキップ
Support for desktop computers by Gateway. Gateway is owned by Acer these days, and anything new by Gateway is supported under the Acer Group.
How do I remove the case off my gateway dx4831-07
i removed some screws on the back but i can't pull or slide the case off
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
i got it open but now the stupid power supply unit fell inside and i cant get it out
さんによる
コメントを追加
1 件の回答
ベストアンサー
Looking at the back of the case. There are 2 screws along the left side of it. Just remove those 2 screws, and that side part of the case will slide towards the back.
The Power Supply appears to be held in by 4 screws, and has various tie down points within the case for the cables.
Ensure the machine is powered off, and disconnect the red/yellow/back cables leading from your power supply to the motherboard. These generally have notch style locks that you can easily undo by applying a bit of pressure, and pulling straight out.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
anthony さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 515
