メインコンテンツにスキップ
マイクロソフト製のハイブリッドノートPC/タブレット。2017年11月発売。
38回答 すべてを表示
Water seeped into the magnetic charging port, and it wont charge. :(
I had my laptop (in a case), the charger, and a cup of water and some other stuff in my backpack. I dropped my backpack and the cup of water exploded and wet the bottom of the bag. I didn’t realise it was a huge issue cuz i kinda forgot my laptop was in there- it was wet for probably 2 hours and water seeped into the charging port and it wouldn’t charge! I turned it on its side with a paper towel underneath it for 10 mins so gravity can draw out the water. I then used a blow dryer (on the cool setting) to help dry the port, and it still wont charge! I can use the C-port but its extremely slow. Its been abt 36ish hours, is it a lost cause?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You’ll have to open it up and clean the area with ipa and check for any signs of corrosion on the board. The liquid has possibly blown a fuse on the charging circuit so you’d need to test it with a multimeter. If your struggling take it to a decent computer shop.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Plz Help 😭 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 70
今までの合計 1,387
