メインコンテンツにスキップ
2019年10月発売のGoogleのPixel 4 XLスマートフォンのリペアガイドと解体情報です。
56回答 すべてを表示
Was replacing battery and made some mess ups.
I replaced the battery in my Pixel 4XL and I had used a pick to pry out the battery while also using a generous amount of isopropyl alcohol. I went down the entire right side of the battery trying to pry the thing out. Then I used a generous amount of isopropyl alcohol to clean the sticker residue. When I replaced the battery I accidentally went through the yellow sticker tab and might have gotten some on the other side of the motherboard.
My phone worked for a while after turning on. It did get warm while charging which was weird. I charged it to full but the screen no longer is working. The phone is on cause I can use voice function and feel the vibration. I removed then reattached the display connecter on the right side but still the screen won't turn on. I am at a loss for what to do. What should I be trying?
Edit:
After having charged it to full and only restarting it a few times to see if the screen was working while trying to repair it, the battery is now at 40%. Could this be right or is there a possibility of a faulty battery causing issues to the screen?
Answer to a question:
There is a yellow pull tab on the battery stickers. I am not sure if I had accidentally pushed through some of the sticker plastic onto the other side of the motherboard but I had taken it out to check and it looks as though I hadn't. I did take all out I could except the battery cause I don't have any additional tape or stickers to keep it in place. I also didn't remove camera lenses, speakers and mic. I did try to reconnect all connectors but so far nothing.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Might of got some what through the yellow sticker? Alcohol? If you put too much alcohol it might of seeped through and into the screen. Make sure as well you haven't torn or damaged any ribbons and remove and reseat all the connections.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
さんによる
コメントを追加
回答を追加する
Aaron Prosser さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 127
