Runs for a few minutes then stops
ok, the machine will run in a working situation for 2 minutes then motor keeps running but vibration stops. The arm that causes the vibrations can be rotated about a half turn and the machine works again for 2 minutes, then stops vibrating again. I'm not going in until I have a plan. I'm thinking the serpentine belt is shot or the pulley it wraps around has worn smooth. Is this common?
The motor continues to run, but sanding stops. they turn the "connecting rod" that runs sander, kick the !&&* out of it, and it runs for a few more minutes then stops. Motor doesn't seem to be overheating
mark さんによる
