My oil light comes one after driving for about 2 hours just flashes
my oil come son if i drive for an hour continuously about oil level if just above maximum
car was recently serviced
the oil pressure sensor was replaced about 4 months ago
Hi,
Check that you have the correct oil filter installed and also the correct grade of oil as this could affect the flow of oil through the engine..
You may have to get the engine oil pump tested (oil pressure test) to check if the oil pump is OK or if there is something else wrong with the lubrication system in the engine.
It is better to get it tested as you don't want to be running an engine that has potential lubrication problems as it may overheat and damage could occur
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 91
