メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
This guide will enable you to be able to repair any issue with your PowerBeats3 Wireless Earphones
volume control button cover came off
Hello
With my earbuds the buttons of the volume control came off. I believe they still work just fine. The glue or adhesive just gave up. What can i use to glue them back down, and is there a preferred way of applying said adhesive?
Thanks!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi
From what you have said I would use the TESA tape that ifixit sells and cut it to the shape you need
If you can provide some photos I can better help you however this may not be necessary
Here’s a guide in how to add photos
https://www.ifixit.com/Guide/Adding+imag...
Also here’s a excellent video on how to repair the volume buttons on any beats in ears
https://m.youtube.com/watch?v=nXSjQzwTDM...
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I have added a photo!
さんによる
@stinder
Thanks for the photo
You could use tesa tape or b7000 glue like in the video
It shouldn’t really matter as ether one will do a good job
Just follow along with the video and your beats will be good as new!
If you need any more help just let me know
さんによる
@stinder, when your volume keys cover came off, did the cable on the bottom also "tear?" I have a similar issue, but it may be more severe and gluing the cover back on will not solve my issue with the bottom cable assembly being torn.
さんによる
コメントを追加
回答を追加する
Bryan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 17
今までの合計 1,267
