メインコンテンツにスキップ
The Samsung Galaxy A22 5G is a mid-range Android-based smartphone developed and manufactured by Samsung Electronics as a part of Galaxy A series. The phone was first released on 24 June 2021. The phone comes with a triple rear camera setup and a 90 Hz display. The battery has 5000 mAh, which is 62% bigger than the battery of the iPhone 13 Pro.
29回答 すべてを表示
My A22 is not operating properly. Cannot get past the Front screen,
Phone reads"Use password after restart" including "Your Password contains at least 4 characters, including at least 1 letter". I can't open my phone, as I can't get past the front screen. How do I repair this, or remove it. I am furious, as it seems to be a Samsung issue. PLEASE HELP ME REPAIR IT. THANKS
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
It’s not a Samsung issue as someone must of added a Lock Screen password at some point. Maybe a 4 or 6 digit number or a memorable word.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hi. Nobody added any Password on my phone. I woke up in the morning after putting on charge the night before, and it was showing this on the screen. "Use password after restart", including "Your Password contains at least 4 characters, including at least 1 letter". This message has been received by many Samsung users, but I need to know how to remove it, as I cannot access my phone at all. Thanks
さんによる
You may have to do a factory reset to remove whatever code is on there. Unfortunately you will lose everything on the phone and you would have to set it up again. You may not of lost everything if it has been previously backed up.
さんによる
コメントを追加
回答を追加する
Robert Clarke さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 857
