メインコンテンツにスキップ
2021年9月24日に発売されたフラグシップスマートフォンは6.1インチProMotion OLEDディスプレイと新トリプルレンズリアカメラシステム搭載、5G対応です。
40回答 すべてを表示
iPhone 13 pro removing MAGSAFE
Hello, im looking for an answer about iphone 13 pro, but i dont find it anywhere. Maybe you could help. My sister wants Iphone 13pro, but the problem is that my nepwhie had heart stimulator (pacemaker) and because of Magsafe it is not recommended to have it near it. Im thinking about buying iphone 13 pro and removing mag safe magnet and wireless charging pad from it, but the question is will it work without it? maybe anyone have tried it or somehow could check it?
Thanks in advance!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi
This is a really good question and I do have a answer for you
YES you can remove the MagSafe magnets but as you will know it will remove the magnetic feature of MagSafe
It shouldn’t remove any features at all but it will void your warranty
You will just have to dismantle the phone until you get the wireless charging coil out and with some heat and alcohol you should be able to pry the magnets out
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Hello, thank you, but what about wireless charging coil? if i will remove it too? will Iphone start?
さんによる
@Vytautas .J
As far as I know there is no reason why the wireless charging coil would cause a issue:-)
さんによる
コメントを追加
回答を追加する
Vytautas .J さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 31
今までの合計 457
