メインコンテンツにスキップ
2020年4月に発表、発売された第二世代iPhone SEの修理と分解情報です。
239回答 すべてを表示
iPhone SE 2020, restarting every 180s because of tg0b, board defect?
Hello Guys, i need help. I have an iPhone SE 2020, replaced screen (by me) which is now kernel panicking and restarting every 180s (has nothing to do with the kernel panicking, screen replacement was done now a year ago). It has no obvious pry damage, the mosfet by the battery connector is still in place and not moveable. With both the OEM Battery and a new 3rd party one the kernel panic keeps happening as well as the 0% battery charge thing. In the logs "missing tg0b" is stated. When starting without the dock and front camera flex attached the logs state "missing tg0b and mic1", so i suppose its a board issue? Any tips?
Update (07/26/2022)
The battery connector
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
One of the data pins looks to be pushed into the plastic but I cannot be certain. The measurements you took are okay.
さんによる
コメントを追加
3件の回答
最も参考になった回答
This does sound like a battery data problem. The first thing to check would be the battery connector as they are known to be problematic on this model. Check the pins have not been pushed into the plastic, if they have you will need to pry them out. The next step would be measuring the pins with a multimeter in diode mode. Also there are two fetts near the battery connector not just one.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
i measured the pins and got the following readings: GND for GND and 418 for the 2 big pads on the other side as well as 689 for the data pins. Ill post in another comment a picture of the connector
さんによる
コメントを追加
Hi Benjemiah,
The error code refers to Temperature monitoring chip on the motherboard stopped working due to no feedback from the temperature sensor it has gone to fail safe mode (restart for every 3 mins)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
So it is not a Battery SWI Problem? How can it be fixed?
さんによる
コメントを追加
See this youtube link: https://www.youtube.com/watch?v=GSH2Y-Sp...
This will show in detail the circuit board issue
This is reference to the Panic restart every three minutes with reference to Mic1 not being found
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
benjemiah さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 17
今までの合計 359
