メインコンテンツにスキップ
The Ryobi RS290G is a powerful Orbit Sander that boasts 12,500 rotations per minute. With an Ergonomic Grip to stabilize, and a dust bag to collect debris it is the perfect all-round sander.
Why is my Ryobi making a weird noise?
My Ryobi sander started making a strange noise and is not sanding proper. I made sure there were no loose screws, cleaned it and then let it sit for a few hours to cool down as I had been sanding on and off for several hours. Unfortunately none of these seemed to help. What could be causing this and is it fixable ?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
What sander is it? Belt, orbital, detail sander?
さんによる
It is a Ryobi corded orbital sander
さんによる
コメントを追加
1 件の回答
ベストアンサー
Possibly a bearing going, either to or bottom. I’d split it in two and remove the motor and check them. Could be wear on the base where the bearing sits.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
bhowse@live.ca さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 801
