メインコンテンツにスキップ
Information and repair guide for the Frigidaire Refrigerator FGHB2866P**A, a non-compact, stand-alone model with automatic defrost but without dispenser, ice maker, or connected functionality. This page covers information for model numbers matching the pattern FGHB2866P**A.
1回答 すべてを表示
Frigidare French door refrigerator ice build up and damage to dry wall
Model: Frigidare FGHF2366PF2
Our 10 year old Frigidare stainless steel refrigerator was not cooling with fridge temperature rising to 55 F. There was some ice deposit inside on one of the vents.
I decided to pull the fridge out and there is a huge piece of ice stuck to the back wall and there is a lot of rust. It looks like its been there for a while. The ice build up eventually made contact with the back dry wall and completely corroded and ripped a hole in it.
Looks like we have to get a new fridge but was wondering why this happened so I can make sure it doesn't happen again. I'll also have to get my dry wall repaired and patched. Going to attach photos for the community. Thank you for your insights.
Update (07/22/2022)
Images are attached.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
The refrigerant that is pumped through the system, changes to a freezing cold gas (at least 0°F) inside the evaporator unit, inside the freezer compartment (behind a panel at the back) to produce the necessary cold temperatures in both compartments. If there is a blockage in the sealed system at this point you can get an ice buildup on the outside of the pipes leading into the evaporator unit from the condenser coils (near the compressor), eventually pushing its way out through the pipe's access point.
The ice comes from the moisture in the air condensing on the pipes and then freezing. This builds up over time as you are unaware of it if the refrigerator temps remain within their normal operating range.
Usually what happens with a blockage in the system is you notice problems with either the refrigerator compartment being too warm and also sometimes the freezer compartment being too warm as well.
One way to keep a check in the future is to once a year, pull out the refrigerator so that you can vacuum the dust build up off the condenser coils under the compartments at the back of the cabinet. This will maintain the efficiency of the cooling system as the condenser coils will release the heat absorbed by the refrigerant in the refrigerator as it passes through the evaporator unit, more quickly rather than it being trapped by the dust. That way you can also check the cabinet over for any obvious problems before it becomes a real problem. Turn the refrigerator off and disconnect the power before moving it as there is AC voltage in proximity in the back of the cabinet
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Rohit Agarwal さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 51
