How do I unscrew the back of the laptop to replace the WiFi card
I want to replace the WiFi card with a better one how do I unscrew the back I unscrewed the screws it's hard to get the back off not trying to hard to break the plastic.
Hi,
I think that you may be out of luck in trying to replace the WiFi card.
Looking at images of the motherboard for the laptop taken from this link there is no removable WIFi card as it appears that the WiFi IC is hard mounted on the motherboard.
The images show the antenna and if you follow the black antenna cable from the antenna back to the motherboard you can see where it connects on the motherboard and that there is no likely looking removable card there or anywhere else.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 15
過去 30 日: 20
今までの合計 99
