メインコンテンツにスキップ
2019年3月に発売されたA12 Bionic チップ、10.5インチスクリーンのiPad Air です。
39回答 すべてを表示
Why can I sometimes not type correctly or touch the bottom of screen?
This started happening after I cracked the top left corner of the iPad.
Sometimes, but not always, when I type, it doesn’t work right.
Example:
I tried typing “example text”
I got “eaple. tet”
Whenever this happens, I can also not interact with the bottom inch and a half of the screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It sounds quite likely that you've damaged some of the circuitry that controls the touch screen function, i.e., the digitizer.
Unfortunately, on your model of iPad it's not possible for the average person to replace just the digitizer glass, as it is fused to the LCD display, so the only option is to replace the entire LCD / digitizer assembly.
There are several sources you can buy a replacement screen from, including right here on iFixit.
iPad Air 3 Screen - iFixit Store
If you're feeling adventurous, there's a DIY guide that will step you through the entire process of replacing the screen yourself.
iPad Air 3 Screen Replacement - iFixit Repair Guide
Good luck, and let us know how it goes!
iPad Air 3 Screenの画像
製品
iPad Air 3 Screen
$199.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Ldangerous1 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 33
