My left earbud is not functioning but my right earbud is wokring
my left earbud is not functioning but my right earbud is working what I do
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi
First I would check that they are both charging in the case by letting the little pop ups appear so that you can check this
After that I would put both earbuds back in to the case and hold the button on the back to reset them and re-pair them
If that doesn’t t work make sure that they are on the latest firmware version
You can check this by going into settings>Bluetooth>Then clicking on the (i) icon
If it’s up to date the version should be 4E71
If all that doesn’t work I would get in touch with apple support if take them to your local apple shop or authorised reseller
Hopefully this helps
Any more questions please ask
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 77
