Why is my rinse cycles just barely dribbling water?
Upon turning on the washer, the water flow is normal. However, when it goes to the rinse cycle, the water just barely dribbles.
Help!
Does it do this on all wash temp settings?
Try the Auto temp control setting of cold/cold and check if the problem occurs.
Initially just trying to eliminate which water inlet valve might be the problem i.e. hot or cold as all "warm" rinses obviously use the hot but maybe not the cold depending on the temp of the hot water supply to the washer. The temp control does not check the water temp on a hot wash, so presumably the cold water inlet valve is not turned on.
Although this might be a moot point if one is faulty because you cannot replace just the one water inlet valve, they come as a module set of two valves ;-(
If you determine that a valve is the problem the part # is 285805. Search online using the part number only to find suppliers that suit you best.
Here's a link to a supplier that may help. It is only to show how to replace the valves - see video on page, not as a recommendation to use them for parts
Not sure with your model but also check the water inlet hoses where they connect to the machine as some have mesh filters in the fitting on the hose that screws into the machine to stop any debris in the water supply - fine silt etc from getting caught in the valve and creating problems. This can cause blockages restricting flow if there is a lot of it. Turn both of the faucets off first and have a bucket handy to catch the water still in the hose as you go to unscrew the hoses at the machine end.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 5
過去 30 日: 33
今までの合計 308
2 件のコメント
Hi @sweetie66
What is the model number of the washer?
jayeff さんによる
26892690, is the model no, jayeff.
MELISSA さんによる
