Adhesive seal...only come with a replacement of Force Touch Gasket?
I successfully relaced a shattered screen, but seems there should have been a replacetment adhesive appliction included in the pkg. A prompt from ifixit that this issue was going to present itself would've been timely The Force Touch gasket is intact, and wasn't part of the repair. The transparent adhesive product that was removed...was to be diposable, right? The watch went back together, and powed up fine etc. Am I missing something about intuitively having to know when ordering the screen, that adhesive wouldn't have logically been included/connected to the part ...if it was certainly going to be required??? I thought well perhaps it on the screen edge and just needs a heat gun blast to activate it. No luck. Having to place another order for something with adhesive, or now taking it to a local shop (which is what I was trying to avoid via DIY) seems like a shortcoming. Surely someone here can chime in and enlighten me as to what I failed to clarify when ordering, or suggest their workaround.
Thanks in advance..JJ
この質問は役に立ちましたか?
