My trunk is stuck on closed
My 2006 convertible VW beetle’s trunk is stuck closed. I can hear the trunk attempt to open followed by whirring after. The red emergency plug has fallen out before I closed it and the emergency latch won’t open it.
hello , try this - fold down your rear seats, remove rear shelf, try to reach the boot handle and remove two screws holding it. then try to remove the whole panel by prying it off of the edges, be careful not to break the plastic clips holding it, then once thats off, reach and undo the latch with a hand , there is a manual release in there, then try to troubleshoot and repair with boot open, - with the latch locked whilst the "doors" are up, . good luck,
このアンサーは役に立ちましたか?
I have a 1999 Beetle and have done this exact thing when my trunk lock malfunctioned. I realize they changed a lot of things on the 2006 and later models and the fact that it's a convertible may factor in, but hopefully what Martin has described will still work.
過去 24時間: 0
過去 7 日: 10
過去 30 日: 38
今までの合計 1,255
