Laptop HDMI port replacemnet
my hdmi port is not working and and ethernet/lan port also lose ..want to fix the hdmi port by replacing
If you want to replace it yourself, you're going to need a new port and some micro soldering tools. I would NOT recommend micro soldering if you are a beginner to repairing, as it takes a LOT of patience and steady handiness. If you don't want to do it yourself, it may be hard to find someone who is willing to take the risk. If none of the above options work, sadly you'll need to replace your laptop.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 697
do you have the tools to do this? or are you looking for a shop?
Logixal さんによる
@logixal i dont have tools ...i tried going to shops but they dont want to take the risk as it may damage motherboard..i need a proper guide on have to safely do it ...so i could show it to shopkeeper or do it myself as last option
Naveen さんによる
I have the same problem but I am struggling to find the part. even shops are struggling to find the port
Cuddle “CuddleAssasin” Assasin さんによる
