It says I'm holding down the RB button? Please help Fix?
I'm not touching RB and it says I am for no reason? I don't know how to fix please help
can u plz send a video to help pervide more info such as if its stuck in or if it clicks cuz u mit just have to take it apart and put it back togeather
このアンサーは役に立ちましたか?
could also be the button but i recement cleaning it taking it apart and then try again
The button is dead and needs to be replaced.
You need at least a solder iron for this.
I had once a similar situation, the LT trigger was always on.
There was a short on a cap in the near of the hall sensor
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 7
過去 30 日: 10
今までの合計 725
[video|4042] okay here you go, I guess it automatically registers as RB ever time I use the controller
Connor Osborn さんによる
