Front camera and home button don’t work after screen replacement
I tried to replace the screen on my iPhone 7 Plus. The screen works fine but the front camera is black and the home button doesn’t click. What should I do to fix this?
does the top microphone work, if not check that you have connected the flex cable correctly to the motherboard and that is not the wrong way around, does touch id work, the home button only vibrates it doesnt click on 7 or 8 models
このアンサーは役に立ちましたか?
The microphone still works, and so does the touch id.
@Nohlin Kamprath you maybe damaged something on the camera flex, button not vibrating could be caused by damage to the home button flex or the screen flex that the home button connects too
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 51
