メインコンテンツにスキップ
Repair guides and disassembly information for the Samsung Galaxy A51 Android smartphone. Released in January of 2020.
20回答 すべてを表示
Samsung Galaxy A51 Startscreen freezes
I have a problem with the A51. Only the Samsung start screen is still displayed. No matter with which key combination I restart it, it only comes up to the Samsung screen. It can also not be switched off. The A51 simply starts again and it gets stuck in the start screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
4 件のコメント:
has it been dropped
さんによる
Which key combinations have you tried?. Soft reset?. Safe mode? Hard reset?
さんによる
Only the combination for soft reset works. Power and Volume up does not work
さんによる
And no it was not dropped. The phone freeze when launching an app
さんによる
コメントを追加
1 件の回答
I went looking for an already existing answer for this and found it has been answered here before. I added a more comprehensive answer for those who have already tried the suggested solutions without success, if you try everything else the last resort is covered in my answer there. Good luck
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Thanks for your help @uchetil but I can't get the device to turn off. When I connect it to a PC, it is not recognized. And the next point, the phone comes not to the Downloadmode or Recoverymode or something else. The phone makes only a reboot and stuck.
さんによる
Then I would suggest you follow this guide to the point of disconnecting the battery wait perhaps five minutes possibly pressing the power button for say 30 seconds and then reattach the battery. This is what a soft reset is meant to emulate. If luck is with you it should fix the problem, I'd get rid of whatever software caused it in your shoes. Let me know if that ails you might try removing and reinstalling the latest driver too. .
さんによる
If you don't want to open it, or if it s still under warranty you could wait for the battery to go flat and try a restart then. Might work, might not after restoring power.
さんによる
If the volume up is not working there's a chance the button is sticking, try working them and perhaps canned air. A stuck button, usually the power button can also cause a boot loop.
さんによる
What app? Instigated the bootloop?
さんによる
コメントを追加
回答を追加する
Ray-K さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 2,164
