My tv is making a screeching noise and then turns it self off.
My tv is making a screeching noise and then turns it self off. It is a hisense tv.
hottie_yankee this could be coming from the power supply board. It contains the high voltage inverters, and the biggest load is on the power supply. A faulty power supply can cause the screeching and shutting down. We would need to see what your boards look like and we could get you to try and measure some of the outputs, once we see what you got going on there. Post some good clear pictures with your QUESTION (edit it) iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 9
今までの合計 253
Can you take the back off the TV and upload pictures of the circuit boards? iFixitでの質問に画像を追加する方法
Andrew S さんによる
hottie_yankee what exact model is your TV? What have you checked?
oldturkey03 さんによる
