only red colour power light is on.
Hey there!
I've instax mini 9 camera. when i turn on the switch only red is working other all lights were not working. may i know the solution or how can i fix it. i'm waiting for your answer thank you.
ragav
Hi @ragav,
From what I remember, and can find; If you power it up and only the red light comes on, it's to do with batteries.
One possible solution is (while the red light is on), push the lens carefully back into it's resting place. (If you feel too much resistance, you're using too much force. It should glide.)
Then when the lens is back in place, you replace the batteries.
It's not 100% it works, but I have done this once myself successfully.
Note: DON'T use force! Careful and consistent pressure to push it back in.
このアンサーは役に立ちましたか?
過去 24時間: 7
過去 7 日: 41
過去 30 日: 154
今までの合計 1,396
