メインコンテンツにスキップ
2020年11月に発売される13インチMacBook Airは、AppleのArmベースのM1 SoCを搭載し、8コアのCPUと最大8コアのGPUを搭載しています。(モデルA2337 / EMC 3598、Thunderbolt 3ポートを2つ搭載)
175回答 すべてを表示
Can I replace dark gray display with a silver display?
My dark gray display is damaged. The store doesn’t have the dark gray display in stock but it has the silver display. Is the silver display compatible with the dark gray MacBook Air? I don’t care about the matching optics. Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi
YES they can do just that
There are no differences apart in the electronics the only difference is the colour:-)
In my opinion I would wait but if you are ready to go ahead I say go for it as it would be unique
If you want it to look normal I would get a nice skin for it
Hopefully this answers your question
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
If they are the same model, then yes, they would be compatible, regardless of color. Apple would not allow you to do this sort of swap, but the parts are functionally the same so it should still work as a replacement screen regardless. So if the aesthetics don't matter to you, then this shouldn't be an issue.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
@flannelist great answer as always. Hopefully you are considering to expand on the About page on your profile. That way we all get to learn a little bit about who we all are and what we stand for. Makes it easier to interact and creates a much stronger community :-)
No pressure of course. It's totally up to you.
さんによる
@oldturkey03 It's on the agenda :) I've been meaning to do it for ages, but alas. ADHD and an ever changing landscape at work means it keeps getting deprioritized. Maybe that will be my task for the bus ride home tonight.
さんによる
@flannelist I totally get that:-) Looking forward to seeing it when it’s up. Bus ride home. How awesome is that! Stay safe
さんによる
コメントを追加
回答を追加する
Kevin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 72
