メインコンテンツにスキップ
Appleの最新で最もパワフルなiMac Pro。3.2 GHz 8 コア、3.0 GHz 10コア、2.5 GHz 14コア、もしくは2.3 GHz 18コア Xeon Wプロセッサ搭載。モデル番号はEMC 3144 / A1862 (ID iMacPro1,1)。
Revert to Stand from VESA Mount
I am looking to sell my iMac Pro that was previously converted to VESA Mount. When I reattach the stand, I cannot get the hinge mechanism to "unlock" and go back to the original position inside the chassis.
Any suggestions on how to reengage the hinge so it can sit back inside the chassis? I feel like any attempts I make to pull or lift with the stand are going to break the assembly.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Thanks. I meant to log in and answer my own question. The only issue with using the tool to reengage the mechanism is that it needs to be bent at a 90 degree angle to catch it. Once I bent the plastic card I was able to get it to pop back in.
It's unbelievable that Apple doesn't include the instructions to disassemble the VESA mount in their 20 language manual.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'm trying to do this right now. Can you go into a little more detail? Did you bend it so that the card went up into the mac, or down?
さんによる
コメントを追加
最も参考になった回答
I haven't done the iMac Pro, but I've done quite a few standard iMac's that have the same stand design. There is a small latch that you need to disengage using the tool that came in the kit or a credit card. Review this Apple manual for the iMac Pro VESA Mount to see where you need to slide it in.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Chris Mammarelli さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 17
今までの合計 1,185
