メインコンテンツにスキップ
Repair guides and troubleshooting for the Whirlpool Quiet Partner II insulated dishwasher.
My Quiet Partner II has no lights
My Quiet Partner II M# DU1148XTPB1 has no lights and I've reset the breaker for the entire house just to be sure
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Check if the door switch (supplier example only) is electrically OK. Here's how to do this.
Be safety aware and ensure that the power is completely disconnected from the dishwasher before testing the switch.
If the switch is OK then check if the dishwasher fuse (supplier example only) is OK.
Be aware that if the fuse is blown then there's always a reason for this and it will have to be found as you may find that if you replace the fuse that it will blow again once the dishwasher has started.
If either part is faulty search online using the manufacturer's part number only (found in links) to get results for suppliers that suit you best.
Cuts power to the dishwasher when the door is opened.の画像
製品
Whirlpool Dishwasher Door Switch - WP8269209
$23.99
Cuts off power to the dishwasher if the temperature gets too high to prevent damage.の画像
製品
Whirlpool Dishwasher Thermal Fuse Kit - 8193762
$37.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Seymone Trueshell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 549
