I accidentally dropped my JBLTUNE 710BT!
My JBL TUNE 710BT was accidentally dropped and now the power button seems stuck... Also, there wasn't any JBL 710BT so I had no choice
@heretofixitems remove the ear cushion and see if that allows you to remove the driver (speaker) that should reveal the circuit board and switch. See if it has become dislodged. If it is broken/broken it'll be difficult to find a direct replacement. you may have to do an online search for a microswitch that will fit the dimensions of yours. To remove the cushions use something like this video to get to it. After that post pictures with your QUESTION if stuck. Adding images to an existing question - iFixit Repair Guide
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 1,092
2 件のコメント
I have the same problem.. please help
abdulkader assad さんによる
@abdulkaderassad did you at least try what was suggested in the answer?
oldturkey03 さんによる
