Phone restarts every 3 min after charge port replacement
I'm having trouble finding the correct charge port to replace my worn out charge port on my iphone SE 2020 model number mhg43ll/a
I purchased one on amazon that was supposed to be the correct part, but when I installed it my phone would restart every 3 minutes. I reinstalled the old charge port and it worked fine, so I didn't break anything, the part was defective. I did some research and discovered that low quality parts can cause this defect, so I bought the iphone 8/SE 2020 charge port (iPhone 8 Lightning Connector Assembly) from ifixit and installed it, but it is causing the same issue.
Does anyone know where I can find the correct charge port that won't cause that problem?
この質問は役に立ちましたか?
