My phone is not charging or turning on
how do l fix it. l really need your help really fast
Sean takarova besides checking your charger, your charging cable and your charging port, let us know what else you checked. It is possible that you have a failed sub board. To make sure, check the flowchart and see where it guides you.
Use your PDF readers search function to find the components listed on the flowchart, in this [SM A205FN SVC board layout. I selected the A-205FN since you did not tell us which version your phone is.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 45
1件のコメント
sean takarova you worked so fast on this that you did not tell us which version your A20 is. There are difference within those versions.
SM-A205F/DS, SM-A205FN/DS (Global); SM-A205U (USA); SM-A205GN/DS (Philippines, Hong Kong, Taiwan), SM-A205YN (Australia, New Zealand), SM-A205G/DS (LATAM/Brazil), SM-A205W (Canada)
oldturkey03 さんによる
