メインコンテンツにスキップ
The Samsung Galaxy A40 was released in April 2019.
20回答 すべてを表示
Why is my phone shutting off randomly?
I have a Samsung Galaxy A40 which keeps shutting down randomly, for some minutes after it has shut off it doesnt want to turn back on and if i try to plug it in a charger it just bootloops. I cant also take a picture with flash or it will shut off, what can it be the issue?
Update (05/29/2022)
also its not a software issue cuz i factory resseted it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
The battery is going out. Here's a guide to replace it:
Samsung Galaxy A40 Battery Replacement
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
thanks i guess
さんによる
コメントを追加
There are other possibilities, @guardian10 is probably correct, but it could be due to for example water damage or a recently added app. If the phone works okay while plugged in to power with the original cable and power supply, but not when unplugged. (Assuming no damage). He is right. If it makes no differences, restart in safe mode to disable 3rd party apps, if it works fine figure out which were installed bout the time the symptoms began. See if uninstalling it fixes things... if no joy a new battery may cure it. I'd recheck the charger and cable first, though.
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
You re right, that factory reset ruled out software issues, I was thinking soft reset!
さんによる
I factory resseted the phone 3 times but didnt help
さんによる
one time it shut off during the factory reset
さんによる
the issues dissapear when plugged in
さんによる
Then that gives you the answer, if it works fine while plugged in: it is time for a new battery. Follow the guide @guardian10 posted above or find a local shop or a mail-in repair service to do it for you.
さんによる
コメントを追加
回答を追加する
usdfudihufd さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 13
今までの合計 1,394
