メインコンテンツにスキップ
will airport work without the display
I want to use my MacBook Pro 15 with an external display since I cracked the display it came with. It won't fit on the keyboard tray with the display attached so I thought I would remove it altogether. When I looked at the directions for removing the display I noticed that the airport antenna is in the display. Will airport work without the antenna? I guess I should also ask: Is there a problem with removing the display altogether? The computer will work without it, won't it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Yes, your airport would be severely crippled if you removed the antennae which are in the LCD assembly. I suppose the rest of the computer would work if you did, and used an external display. If you have a wired LAN cable connection, you may use that instead of the Airport to connect to the network.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jennifer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 549
