メインコンテンツにスキップ
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
20回答 すべてを表示
Computer turns off with a click sound after about 30 seconds?
Hi,
I started to have this issue a few days back. When I switch on my acer netbook, everything is fine, it boots up; but about 35 seconds after switching it on (yes, I timed it and it happens after so long consistently!!!), it makes a clicking noise and just turns off!!!
I have already tried to flash the BIOS, but it did not help.
Here are my system specs:
model: Acer Aspire One 8.9 inch, ZG5
OS: Ubuntu 11.10
HDD: 160 GB
RAM: 1GB
Any help on what to do or where to look would be greatly appreciated!!!
Thanks.
Regards,
Ani.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
最も参考になった回答
Over heating, cooler does not work propelly...
I have same issue with every update on ubuntu...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This is common problem with ZG5. It is the fan. Upon disassembly, you will note the fan has three leads. One for power, one for ground and a third lead that senses fan rotation. Check for free rotation of the fan and correct or replace and your problem should go away.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ani さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,718
