メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
Mute Switch Flex Cable Repair
Hey,
I need to replace my volume cable as it broke but im confused to as how it works. I’ve looked for replacement parts but all of them are missing the physical mute switch and one with a mute switch is stupid expensive. Would you happen to know how the mute switch is attached to the flex cable? Is it soldered or does it just clip in like a flex cable. My issue is with the iPhone 8P but i'm pretty sure its standard across all iPhones.
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The physical mute switch -- that is, the piece that you move back and forth with your finger -- is not part of the cable assembly. The flex cable has a tiny internal switch that sits in a recess under the physical mute switch.
Although it's not in English, watch this video starting at 3:04 and you can see how the assembly comes apart, and at 4:08 in the same video you can see the technician separating the flex cable from the physical mute switch, giving you a pretty clear view of how they mate.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
That is for the iPhone 6s, he has an iPhone 8, the switch construction is different to allow proper sealing for water resistance. I haven't found any video on how to take the rocker off the switch yet.
さんによる
Construction (in that regard) is the same between the 6 and the 8. That's why the video is entitled "6/7/8".
さんによる
@steve_g no starting with iPhone 7 there is additional water resistance design around the rocker. I’m not sure if OP want to preserve it.
さんによる
@tomchai The only difference is a minor small gasket. Construction is the same.
さんによる
コメントを追加
回答を追加する
Jaydan Reynolds さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 21
今までの合計 341
