Will this broken pin have an issue if I replace the display?
Will that pin cause an issue if I replace the display, its an samsung galaxy s5 neo which has been dropped from 3rd floor, still works though but display is dead
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@udduudduudud yes it will. That is the display connector and all the pins are being used. You can try and gently bend it back in place or you will have to do a board repair by replacing the connector.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 72
