メインコンテンツにスキップ
Released in May of 2020, Model Numbers: SM-A217F/DS (Global), SM-A217F/DSN (Russia), Processor: Exynos 850, 3GB/4GB RAM, 6,5" inches display, 5000 mAh battery with 15W fast charging and USB type C.
108回答 すべてを表示
Why is my phone slows?
It runs slow how to fix
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
5 件のコメント
My phone is very slow
さんによる
My phone is not working fastlu
=== Update (08/05/23) ===
It runs slow how to fix it
さんによる
@uzumakinar10212
Did you try what was suggested in the Most Helpful Answer below?
If you don't try things already suggested here and then reply if it worked or not then there may be other things that you can try but do them first!
さんによる
My phone slow idont khow
さんによる
Tower slow problem could not connect
さんによる
コメントを追加
4件の回答
最も参考になった回答
Hi @abudi78
Try the following and check if doing any improve performance.
  • Wipe the cache partition
  • Try using the phone in safe mode. If it works OK in safe mode then a downloaded app may be the cause of the problem. The trick is to find out which one. You will need to uninstall each downloaded app, one by one and test the phone in normal mode between each uninstall. When it works OK the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed on the phone and didn't come pre-instaled on the phone when you first got it.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
There are a few reasons that a phone can slow down. Attempt a restart of the phone by pressing and holding the power button and the volume button on the side of the Samsung Galaxy A21s until the screen turns off. After turning it back on see if that helps the issue. Otherwise, it could be an issue with how much data is on the devices storage. See if you can unload some data and see if that helps the issue.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Try restarting the phone, and checking your phone's system health (you can do this by opening Settings>Battery and Device Care and performing the necessary actions for each category). This will also help you free up space with the help of the corresponding tab. Additionally you can also check for system updates by opening Settings>Software update>Download and install.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Well I will suggest you to scan your phone of junk file by using a good phone cleaner app and also delete the duplicate photos from you phone because we all have so many photos in are phone now day that also fill are phones memory that also mark are phones slow as well.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Abdusemed さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 26
過去 30 日: 57
今までの合計 2,095
