メインコンテンツにスキップ
Released in 2019, these wireless headphones have digital noise cancelling technology and came in a variety of colours. These can be identified with the model number WH-H910N.
2回答 すべてを表示
Noise Cancelling malfunctioning after disassembly
Ever since I took apart my headphones (as part of the repair guides I made for these headphones on iFixit), the right earpiece's Noise Cancelling has malfunctioned.
It makes crackly sounds and a weird fluctuating pressure that kind of feels itchy, and when it gets pressurised enough in the cup, it makes a really loud, almost pulsating whistling sound. I have to use these headphones without the noise cancelling at the moment to prevent this from happening, which is a big shame.
I've reset the headphones to factory settings, which didn't fix the issue either.
I've inspected the solder joints between the NC mics and the PCBs and they seem fine (but I really don't know much about soldering and I don't have a soldering iron). I'm not that experienced in this sort of technology so I don't know what the underlying issues could be, or what I could even be looking for, really. :S
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Did you ever find the solution? This exact issue has been happening to mine, and I originally thought it was because the mic cables were shorting out with each other, so I've opened them (three separate times) and put electrical tape on the cables to ensure they don't touch each other, but that only worked for a day. These are refurbished pairs, but I don't see any sign of damage or anything wrong with the headphones themselves
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Unfortunately not, I ended up just buying a used pair of XM3s instead x.x
さんによる
コメントを追加
回答を追加する
Caius Nocturne さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 87
