メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
PlayStation 3 (PS3)はソニーコンピューターエンターテイメントによって製造された3世代目の家庭用据え置き機で、PlayStation 2の次世代機となります。これらは2006年11月11日に発売されました。
Will Not Power up
Hey Peeps,
Ive researched as much as i could, but their is no problem similar to mine, well not that i could find through google or through any of the questions made on ifixit, i hope you i can get anyones help? it would be much appreciated, i really dont want to move on to the slim 0_0
now
Im not 100% sure as to how it happened, but according to my little brother who was playing as i was away, played and made an update for MW2, after it had finished, it would not turn back on
so
Problem:
PS3 has the red light as soon as i turn on the AC power switch on the back,
As soon as the power button is pressed, it disappears and nothing happens
try turning the AC switch on and off, red light dosent come back at all
Solutions attempted:
  • replacing the power supply unit
  • old 40GB PS3 hard drive (unformatted)
  • new AC power cord
After Replacements were made:
AC switch on, Red light would appear, i press the power switch its goes green for one second then disappears and never comes back again
Where im stuck:
Is it the YLOD?
Is the motherboard fried?
Should i replace each and every part that could relate to the problem?
ive read replacing the ejection button ribbon cable might help? (which ive ordered)
Any help would be awesome!
Cheers
John
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
Hi everytime I start the ps3 the power cuts out how can this be fixed
さんによる
コメントを追加
3件の回答
ベストアンサー
http://www.ps3-help.com/activate-ps3-saf... this for safe mode which you haven't mentioned...
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
Sorry, ive might of missed a few things out,
Once the power button is pressed, absolutely nothing happens.
Nothing shows on the TV screen at all, no sound from the console, no nothing.
Power cuts out completely, and doesn't come back
Safe mode is inaccessible because im unable to reach the stand by screen at all
Thank you for the help :)
さんによる
コメントを追加
I have same problem with ps3 slim what can I do for fix?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I've got the same problem with my ps3 super slim did you get a solution for it please let me no.
さんによる
コメントを追加
The internal power source is not making sufficient contact to the two protruding pins take out the power source and put it back in and press down on the power source to ensure your making good contact, should take care of it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
John Filipo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 20
今までの合計 12,103
