メインコンテンツにスキップ
Appleはスリムダウンして性能を上げたiPad Airを2013年11月1日に発売しました。スペースグレーとシルバーの2色から選べます。カスタムA7 プロセッサー搭載しており、容量は16、32、64と128 GBがあります。
577回答 すべてを表示
Ipad restart loop after replacing parts.
I have an Ipad Air and i have fitted a new battery and digitiser for it. I decided to do a test of the ipad to see if the new battery and digitiser worked and while the ipad does turn on, it turns off shortly if I drop it from a small height of around a cm or so. It does not do this if i apply pressure to where the LED connector and digitiser connector shield is, is this a result of improperly fitting something or do I simply need to apply the digitiser adhesive and seal the iPad once and for all since that might apply enough pressure across the entire LED? It also gets stuck in a restart loop from time to time.
I also understand that the Ipad can turn itself off if something comes out of its place leading me to believe that the battery might somehow also be improperly fitted?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Just because of the "turn off after a small bump" issue I'm going to say that the battery and/or logic board are not fully in place. Bumping as you describe would shift the electrode contact just enough to turn the unit off and on again. Your application of pressure near the location would also go with that.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Would seem that leaving it fully untouched for a couple of minutes also sends it into a restart loop now, not sure what it could be
さんによる
Might be heat-related, if it was off _just_ enough that contact was lost when heat expansion took place.
さんによる
コメントを追加
回答を追加する
No Man さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 45
