keurig not forcing water through when cup is insterted
when cup is not in water will flow...however doesn't seem to be forced through...just kinda gravity taking effect. When cup is inserted, the water doesn't make it through at all and machine freezes up
この質問は役に立ちましたか?
7 件のコメント
I had this issue as well. Ran the vinegar thru ended up having to unplug and reply to get that 2nd cup going on vinegar, then ran second vinegar, then by the 3rd water rinse it was working to stay plugged in. But when I add a cup in it, it's like just flowing thru, dripping, now only 2days after running vinegar I'm getting half very strong cups, and descale is on screen again.
Stephanie さんによる
I have descaled the 2.0 (two times in a row.....one using the Keurig solution, and again using vinegar. I have cleaned the needles with paper clips and cleaned the needles with the little orange attachment. The coffeemaker will run 10 ounces when there is no k cup......but, the water continues to leak a bit, even with no k cup installed. This is very frustrating.
3/31/19. Hap
hap60 さんによる
I’ve got a similar issue, I descaled it last weekend and it worked fine for a week but now it brews but doesn’t force the water through at the end. The kcup stays full of water so when you open the top it starts dripping out. I’ll try running vinegar again I guess.
ryann.grasso さんによる
When the machine is working properly, there is a burst of air that empties the remainder of fluid in the k-cup. This stopped happening after a recent descaling. The result is a partially-empty K-cup that leaks the remaining coffee or tea after you open the machine in order to remove the used K-cup. I leave my coffee cup underneath to capture the additional coffee, but the machine is clearly missing a step before completing the cycle.
I’ve decaled the machine twice and also cleaned all needles (entry and exit), but I know the problem is with the missing air flow step or whatever that rush of steam is.
trdrum さんによる
We are having this exact issue with our Keurig 2.0 I wish I had a solution to share.
Sam Watson さんによる
2件以上のコメントを表示
