メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年3月に発売されたSamsungの機種です。モデル番号はSM-G930Vです。
Screen Flickering When Charging - Grounding Issue?
Hi there,
I've repaired a Samsung Galaxy S7 with a replacement screen (the old one was smashed and completely dead.) The replacement screen came with the frame and a new charging port assembly.
The phone seems to be working great after the screen replacement. However, when charging the phone, the screen slightly flickers. This only occurs when the phone is being held by the metal sides - if it's in a case (e.g. the metal sides are not being directly touched), there is no issue.
This sounds like a grounding issue to me. The charging port assembly cannot be easily removed by the looks of it, as it seems to be attached under the screen. I've also tried another cable and charger, which presents the same issue.
Is there any other likely cause of this grounding issue? If anyone could provide any pointers I would be very grateful.
Thanks for your help!
Ben :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
This happened to a friend of mine and found that the digitizer display was slowly going bad (dying),
It was still under warranty he got it replaced and had not had any issues thus far.
Good Luck! :-))
~Ibuprophen
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi,
Thanks very much for the help! I'll see if I can get a replacement display assembly.
All the best,
Ben
さんによる
コメントを追加
回答を追加する
Ben Garrod さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 41
今までの合計 3,510
