Diagrams of all Folds in Front Camera Flex Cable
I find it impossible to find 1 or more diagram(s) that clearly show how to make all folds in an iPhone 8 Plus Front Camera and Proximity Sensor Flex Cable in order to perform a replacement.
hello Michael,
you won't find it anywhere. Start with the speaker contact, this one has two holes and fits perfectly in its place. Then stick the microphone. The two holes mentioned earlier will perfectly fit the microphone in the right place. Two sensors remain on the sticking out belt - if you use a high-quality screen or the original, there will be places for the sensors. If not, set the left one first and the right one must be adjusted to the position of the window. Press the speaker lightly at the end and the tape will fold itself. Tighten the screws and that's it. Don't forget to check the operation of the sensors.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 123
