メインコンテンツにスキップ
Xbox 360は、2005年11月22日に発売されたMicrosoft製第二世代ゲームコンソールです。
428回答 すべてを表示
Xbox power supply flickering green and orange.
Hi, my Xbox 360 isn't powering on and the power supply is flickering between green and orange. The console itself has the center green light lit on the power button and is clicking (No HDD installed and I presume its the fan attempting to spin up?) anyone have any clue what the issue could be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@macintoshing the PSU has built-in safeguards to help prevent damage to either the console or to the power supply itself. It will turn off in cases of over current, over voltage and over heating. Whenever some situation like that occurs the light will turn from green to orange or to red. I suggest that you take a look at the possibility of it overheating. Use this guide Xbox 360 Power Supply Teardown to work on it. Or if you are stuck with anything while working on it, you can always post images with your QUESTION. iFixitでの質問に画像を追加する方法
Xbox 360の画像
ガイド
難易度:
中レベル
15 - 30 minutes
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I second @oldturkey03. I have experienced this myself and found that due to excessive buildup of dirt and other particulates in the intake and exhaust of the power supply, the unit would regularly overheat mid gameplay. Upon clearing the vents, I was able to gain extended periods without the overheating however, I believe the power supply was ultimately damaged from many overheating events prior to my realization that cleaning was needed as it eventually died, and I had to purchase a new one.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Macintoshing さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 42
今までの合計 697
