メインコンテンツにスキップ
Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
removed dvd drive, now fan goes on indefinitely
HI
i had to remove a faulty dvd optical drive due to crazy noise, iam planning to order a replacement but what is happening now is tat the fan is going at full speed, right from the start up, is this normal?
hi i have a iMac 24 inch (white) 2.33Mghz core 2 duo, ((((i dont see no ECM number on the label so i cant say if i am giving you correct info)))
Here is what was in my system profile:
Computer details
Model Name: iMac
Model Identifier: iMac6,1
Processor Name: Intel Core 2 Duo
Processor Speed: 2.33 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache: 4 MB
Memory: 2 GB
Bus Speed: 667 MHz
Boot ROM Version: IM61.0093.B07
SMC Version (system): 1.10f3
PIONEER DVD-RW DVR-K06:
Firmware Revision: Q609
Interconnect: ATAPI
Burn Support: Yes (Apple Shipping Drive)
Cache: 2000 KB
Reads DVD: Yes
CD-Write: -R, -RW
DVD-Write: -R, -RW, +R, +R DL, +RW
Write Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO
Media:
Type: DVD-R
Blank: No
Erasable: No
Overwritable: No
Appendable: No
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
you guys are right, i did forget to reconnect a thermal sensor, its in my hand :( with the old drive.
Thanks allot
さんによる
コメントを追加
2件の回答
ベストアンサー
Sounds like you forgot to reconnect a thermal sensor, there are quite a few of these throughout the computer, and forgetting the reconnect them will result in the computer thinking that it is overheating, and reving the fans up to full speed. Thermal sensors ususually use 2-Pin connectors, and can be easy to forget to reconenct.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Recheck all your connections
esp. the ones to fan and heat sink. You could have one that "looks connected" but isn't, or you may have damaged a connector.
Good Luck,
N.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Gabriel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 3,913
